Texecom Alarm System + Protect 375
29 Apr 2024
In short; The 375 Smoke Protect System requires primary and secondary triggers.
Both must be external 12v to trigger the smoke generation.
I've taken the primary 12v from the bellbox (bell) trigger.
The secondary should be from a PIR to detect motion in the room the smoke system is installed in before activating.
I've attached manuals to both systems. Please note that OPT3-4 is not available on this system.
I need to trigger the secondary on 375 smoke protect with 12v coming from the PIRs however the pirs I have are resistance based and do not output 12v on alarm/trigger. What can I do?
  • Protect 375 Installatie en gebruik - NL53.nl.en.pdf
  • INS176-6 (Premier 48,88 & 168 manual).pdf
All the smoke units I’ve ever installed had output from the alarm ( primary ) then a local pir wired to the smoke unit ….so either 2 devices needed to activate the smoke machine …see page 16 ?
Just fit a device with a relay onboard to activate the confirmed intrusion….
