Confused American: Joint Compound vs Filler vs Spackle
30 Apr 2024
Hi All, I recently moved to the UK and am confused about the various fillers and joint compounds. I’m fixing a corner where the wall meets the ceiling and putting in new joint tape. What should I use and can someone give a quick rundown?
What’s the equivalent of “mud” in the US?
Is polyfilla spackle? Are all “fillers” spackle? Jointing compound seems like what I want, but it’s the same name as a product used on pipe threads? Help!
Spack over here is finishing plaster i.e. Thistle Board Finish or Thistle Multi-finish.
Those that prefer to mud the joints only and fill the fixing holes (and sand down) use Easy-fill.
Large Building sites tend to go with dry wall and mud.
Private house building and extension tradesmen (re-modelling etc) tend to plaster the lot - i.e. Thistle multi or board finish.
Corners - we fix metal (thin-set) board beads.
