Help…
My Robus thermostat stopped working - light was on but not calling for heat. I removed it and took picture of wiring (see first image) and thought the wiring would be the same on the Honeywell T6360! Wrong!
The numbers did not match on wires - 5/6 has no screws in new fitment (see image2). Also the new fitting didn’t seem to need the link wire I found a lion here that suggested wiring but popped fuse. I then found another wiring diagram in here and the light came on but thermostat didn’t call for hear. I presumed I’d damaged the thermostat so got another one.
Before I botch this up can someone please advise on wiring - I have a brown wire , black wire with a brown sleeve on and a blue wire with grey sleeve on it….(see image 3)
